Problems with Thermostat in a 1997 Sonoma GMC V6
  • jaflores67
  • Avatar de jaflores67 Autor del tema
14 años 6 meses antes #10238 por jaflores67
Hi, does any one had a problem with the thermostat not making contact in the base? I aleready bougth a new thermostat but it is even worst, this is causing the temperature do'nt raise, I first thougth that there were no thermostat, I verified and the thermostatwas there but it is not making contact in the base so I bought a new one but it is worst, if anyone knows something about this I will apreciate any information. Thanks and regards.
14 años 6 meses antes #10478 por Jueja
Respuesta de Jueja sobre el tema Problems with Thermostat in a 1997 Sonoma GMC V6
Try OEM.
12 años 8 meses antes #25481 por magu2090
Respuesta de magu2090 sobre el tema Problems with Thermostat in a 1997 Sonoma GMC V6
checa que este limpio o libre de silicon. o materiales del anterior termostato, si no encuentras las juntas originales aplica silicon suerte amigo. swaludos de queretaro mexico.
Bernardo y 9887 otros tienen se unió al grupo Manuales de Taller de Motos 7 días
